The idea is to create an option/property node to draw chart vertically. I know, that it is possible to workaround with XY Graph, but still you have to add some other functions to your application. Moreover drawing chart vertically using image change would be faster than making changes in the code.
Pawel
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-axis-swap-for-Waveform-charts-graphs-and-intens...
