13 | |
11 | |
3 | |
3 | |
2 |
This is a very simple improvement, since the features are almost there. I want the block diagrams look like an electric diagram, that is: Controls aligned to the left, with the labels on the left of the control and the indicators moved to the right with the labels on the right, like this:
The problem is that in current LV versions the alignments occurs on the labels as well, making look the diagrams like this:
Normally you should: 1) align labels relative to the object and 2) align the objects (without the labels) relative to the block diagram. This kind of cleaning up saves a lot of space and clutter.
Now I am pushing my luck, but it would even be better if I could have these settings on SubVI's only, because I usually don't want this in my main.
Good luck
