Sometimes it's just easier to see all the properties of a control and an indicator in one overview. => a property manager screen which can be switched on.
If you select a control/indicator the properties of that control or indicator are shown.
From this screen you can adapt every property by editing text or selecting a value from a downdown list.
Property manager has two tabs :
- General : general settings (e.g. label = array ; representation = I32)
- Appearance : apearance settings (e.g. show caption = true)
