3 | |
3 | |
2 | |
2 | |
1 |
Problem statement: we can't draw ROIs programmatically with different colors.
Right now we can draw ROIs with the same color only:
Conversion to overlay is the only way to draw different colors:
Suggestion:
Give the possibilities for setting ROI's colors individually (replace RGB cluster with array of colors):
In the same time it should be also possible to define color for the next new ROI which will be created by user.
Forum's References:
Different color ROIs
How to set different colors to different ROIs in one image
Change color of ROI GROUP
