6 | |
5 | |
2 | |
2 | |
2 |
Problem
At this moment when I create constant on Which Event Input (Get Last Event Method):
it looks like that:
and every time I should go to help to check which number is responsible for Click, which for Draw, etc... (Usually I using Ring constant obtained from IMAQ WindLastEvent).
Compare it with IMAQ WindLastEvent function:
Suggestion
Do the same in Get Last Event Method. Please replace meaningless array of I32 with array of Ring Constants:
Andrey.
