The Problem
Doing a long finite acquisition in DAQmx results in the manner shown below results in a all the data from the acquistion residing in a 2D array of waveforms that the user must rearrange to begin working with. Since a 2D array of waveforms is not really useful with any processing functions in LabVIEW, why not come up with an automatic way to get the datatype you want (a 1D array of waveforms with the new samples appended to the Y array of the appropriate channel.)
The Solution
Give the user the ability to create a "waveform autoindexing tunnel" via a context menu option. This tunnel would automatically output the appended waveforms, 1 per channel. This could be done behind the scenes in the most memory efficient way possible so as to save users the headache of trying to modify the 2D array they currently get.
Zoomed in Images
