13 | |
7 | |
3 | |
3 | |
3 |
I think it would be nice if LabVIEW was smart enough to know that when I drop a For Loop around scalar inputs it doesn't auto-index output tunnels - but rather uses Shift Registers - for matching inputs and outputs.
The common use case for this is with the Error input/output - it annoys me how it becomes an Array output.
As it is already wired, inline and not broken, dropping a For Loop around it should not break my code!
Reference or Class inputs are other use case too - I want to pass the same thing around not create an Array.
Shift registers are better than non-auto-indexed tunnels (other option) as they protect the inputs on zero iterations.
This would remove one step required for most use cases, speeding up my development experience.
Implemented in LabVIEW 2014
