6 | |
5 | |
2 | |
2 | |
2 |
When you use Find Callers and want to see into the SubVIs you left click for selection to view a pop up window showing the searched for item with x", which can be set, on all sides of the searched for item.
When the item is used more than once in the displayed SubVI add forward and next buttons to the bottom of the Find Callers window to loop through the items in the selected SubVI.
This would make it a lot faster finding the exact code that is needed instead of manually searching through every SubVI that comes up on the search.
