Andrey_Dmitriev
When the Library is locked because not loaded - explain why the library is not loaded
Status: New
During renaming nested libraries in my project I've got the following message:
Please add into this dialog explanation with the reason - why my library is not loaded? (not found / not licensed / corrupted / etc)
This might be also related to classes.
Thank you.
2 Comments
chokkk
I have the Same Problem
RavensFan
Knight of NI
If you have the same problem, then you should consider clicking the Kudoes button to give you support to the idea!
