When creating an installer for a Labview project it is possible to add Registry keys. But only with type REG_SZ and REG_DWORD.
Make it possible to add keys with other types. Often it is necessary to use the expandable String Type REG_EXPAND_SZ when adding path entries using for example %ProgramFiles% variable.
