It is written in the help of 'Split Number Function' that "If you wire an 8-bit integer input, this function does not split the number."Why Labview does'nt support splitting of a byte into two nibbles??Some times we need to split a byte into nibbles.It is programatically possible with a loop and shiftregister.But Iam asking this because we already have a Split Number Function then why not providing another to split a byte into two nibbles??
1 Byte Nibbles
