Jack_Jim
Why not removing "Invalid" & "Closed" two values of FP.Open Invoke Node
Status: Declined
we have a parameter "State" which can only be written.
This "State" parameter have six values: Invalid, Standard, Closed, Hidden, Minimized, Maximized
If we set the parameter as Invalid or Closed, we will get an error.
Why not removing these two values here?
13 Comments
tst
Knight of NI Knight of NI
Knight of NI
Because the state can also be read as a property and it's an enum - the enum has to have all the values.
___________________
Try to take over the world!
Jack_Jim
NI Employee (retired)
Just maintain consistency with the enum output of the FP.State property node?protertity-node.png
tst
Knight of NI
Why not? Consistency is important. It becomes even more important if you were to use both the property and the method together, because then the enum values would not match.
___________________
Jack_Jim
I agree consistency is important, however, if we use this method: invoke-node.png
Invalid and Colsed, two enum values, would be useless. We can not set "State" parameter as these two values, which makes our customers confused.
RavensFan
Knight of NI
Then that fact should be noted in the documentation of the property node that it is invalid to write those two states to the property.  I wouldn't change the enum.
SteenSchmidt
Trusted Enthusiast
@RavensFan: It is noted in the documentation already.
/Steen
CLA, CTA, CLED & LabVIEW Champion
Darin.K
Trusted Enthusiast
It would be kind of cool if those two values were disabled automatically in the created enum control/constant.
Jack_Jim
@Darin.K: Yes, I really agree with you.
tst
Knight of NI
Another possibility for implementing something like this would be if LV had sparse enums - then this list could display only some of the values and the enums would probably still match.
___________________
AristosQueue (NI)
No, it wouldn't be cool. Because then someone would ctrl+drag their enum constant somewhere else and complain that it was disabled. Or, if we made them reenable on copy, ctrl+drag it to another FP.Open and complain that it *wasn't* still disabled. And so on.
It would not be cool. It would just be weird and annoying.
