NI-hilator
Windows Shortcuts (.lnk) Become Part of LabVIEW Expected File Path
Status: New
After much frustration searching the Labview help and NI website I finally came across the reason why my project kept coming up with vi file conflicts and/or using the incorrect version of a vi.  Apparently when searching for a vi, if there is a windows shortcut (.lnk) in the search path, it follows it!  Now this is a very powerful feature but a dangerous one too.  Apparently this has been a feature of Labview all the way back to version 1.0 This fact is not mentioned anywhere in the Labview help but I did finally find this article: http://digital.ni.com/public.nsf/allkb/B43C655BA37AFFA0862575EC0051E936
In my case I have lots of example code on my PC. I often put shortcuts to similar code in the same folder with VIs and project as a quick way to reference alternate methods of accomplishing similar tasks.  No problem, I'll just turn off this feature in the VI Search Path page of the Options dialog, right?  Much to my surprise there is no way to turn this off.
Suggestion: Please add an option to disable this feature in the VI Search Path page of the Options dialog.  Even if this option is dismissed and not implemented, please at least add this information to the Labview help, perhaps in the Paths Page (Options Dialog Box) if not in several other places in the help. It would certainly have same me hours of frustration and lost productivity.
12 Comments
sci7
<for anyone searching in the future>
bbrisson
OK try this:
 You should end with the path and the file name that correspond to the link file.
