I will write this off to my **bleep** retentive personality, but what about an option that would allow wires to enter/exit structures from the left and right sides of the structure only? The left would be enter / the right exit. When the source of the wire is not visible, and the entry/exit point of the wire is on the top or bottom of the structure, I sometimes find it hard to see the data flow direction.
