6 | |
6 | |
3 | |
2 | |
2 |
After a brief search I didn't see this one yet:
As I'm gradually changing over my wire labels to the "new" method, I'm noticing some quirks regarding positioning. I'd like to suggest the following:
I'd like to emphasize the "option" part on the latter, as this understandably won't be a good fit for every context.
As with other suggestions, I realize that this is somewhat subjective, so here's an example of how I'd like to use the labels.
Here I've aligned all of my labels on their horizontal centers and have set the respective fonts to center justified. My intuition tells me that, now when I start typing, all of these labels should remain aligned on their horizontal centers. However, when I started typing out "Enable Speed Per Air Flow Rate", the whole label started wandering off to the left. I don't quite understand how the alignment works, but it's not proving efficient in most of the instances in which I use it.
Thoughts? Improvements on this suggestion?
Thanks as always,
Jim
