LabVIEW 2010 introduces a new feature to label wires and associate this label with the wire. This is a great idea. However, the text goes over the middle of the wire and there is no way to change/customize this.
To me, wire labels should be above the wire. This is the convention on circuit diagrams. Placing a label on a wire "breaks" the wire and, to me, is similar bad-form to placing any other object on a wire.
So what I would like is shown below. There should at least be an option to allow the wire's label to be above the wire.
