13 | |
11 | |
3 | |
3 | |
2 |
I use an electrical drawing package and on different pages of schematics it is nice to have copied components e.g. potential lines to be in the same position so when flicking through pages you can easily see the differences and it looks prettier.
In an event structure or case structure when I copy and paste an object from one case to another I would like to be able to also copy the position of the copied item. I like to be able to scroll through event structures and see any identical components in the same location.
I propose that the X and Y keys on the keyboard be used to trigger this auto alignment so that after pasting, pressing Y will move the copied item to the same Y position and then X to move to X position.
