10 | |
3 | |
2 | |
2 | |
2 |
I like to suggest adding a possability to show the text definition of signal values inside the XNET database editor, (e.g 2 => 'moving'). Right now I need to open another tool to check the meaning of a value that is already describt inside the opened dbc.
