11 | |
8 | |
3 | |
3 | |
2 |
There seems to be a control missing in LabVIEW: an intensity plot that will accept data that has been sampled at a variable rate.
It should be possible to specify the time stamps of each block in the plot (like with the XY Graph) so that you can present such data without having to resample it at a fixed rate.
