Jim12345678
add a timed strip chart
The current strip charts display data a fixed intervals.  If I want to plot data that is collected at inconsistent intervals I have to use a XY chart and record the paired data.  How about creating a strip chart that displays the data against the time it was added to the plot?  The program provides the Y value and the x value is just the time the data was plotted.  The plot could have a time constant for the entire window much like the scroll rate used in actual paper chart recorders (e.g. 1 cm/minute).  In other words, one could configure the chart to have a span of 1 hour.  After an hour, data would get "pushed" off the end etc..
12 Comments
donkdonk
@AristosQueue,
[..]this request to be a bad idea to ever add to LabVIEW[..].
Now that you understand want is meant with the idea (as pointed pointed out in the other thread), could you consider changing this reply?
AristosQueue (NI)
NI Employee (retired)
Reply is still "closed as duplicate". But with the clarification in the other thread, yes, I can see the utility of the idea.
