Would it be good, on the Graph Properties page, Plot tag, one can set up the Y-scale to left or right? Good idea? Give this idea a Kudos!
At present, one can achieve a two Y plot by: right click the Y axis, Duplicate Scale, Swap Side, and often confused with which plot is associated with which data set. A cleaver package like LabVIEW should not need to do this. Just look at what Mathcad does.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
