 BrianKincaid
			 on
		07-24-2009
		01:05 PM
			3 Comments (3 New)
			BrianKincaid
			 on
		07-24-2009
		01:05 PM
			3 Comments (3 New)
		I'd like a new hotkey to remove only broken wires with no connections instead of all broken wires.
Example:
Using State machine with several shift registers. Now I decide to move a shift register variable into a cluster or something. I delete the shift register and tunnels. I now have lots of broken wires but I only want to remove the ones that have been wired 'through' with no connections. If the others remain so I know that I should handle them.
Thanks.
Brian
