wbadry2
cometic change on build array output terminal
Build array is one of the most VIs used with shift register.
 It is always a bit annoying from UI perspective only to see this curly line which would be much better if connector of appended array is moved below as proposed in the picture above.
KInd regards,
Waleed El-Badry, MSc., CLAD MCPD
5 Comments
crossrulz
Knight of NI
I would actually prefer it to be on the top since you should be adding items to the end of the array instead of the front.  And I am certain this is a duplicate.  I'm just too lazybusy to go search.
RavensFan
Knight of NI
wbadry2
Thanks RavenFan for pointing out to this thread. I'm glad that someone asked 7 years ago and got no response.
KInd regards,
AristosQueue (NI)
NI Employee (retired)
This idea will be closed as duplicate. The OTHER idea will be closed as "Complete in LabVIEW NXG". The realignment of terminals across the board is one of the major changes made in the new platform.
Darren
Proven Zealot
