11 | |
7 | |
3 | |
3 | |
2 |
So, in some inherited code there's lots of Compound Arithmetics where the input wires are either random or reversed from a neatness perspective.
It seems the Ctrl+click switcheroo only works on the 2 input version, and it'd be good if it worked on the larger ones. The way I see it work is either:
1. Hover over the input separator to switch those two specific inputs, which'd make a full reversal a sort of manual Bubblesort
2. Like the VI input selector, where you can select one and Ctrl+click another to switch those two.
(Atleast I cannot seem to do it in LV2017)
/Y
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Use-the-wiring-tool-to-swap-inputs-or-outputs-which-h...
