8 | |
6 | |
4 | |
3 | |
2 |
All the time I make type def enum's in order to use with a state machine. Most of the time I create the enum from the block diagram instead of the fp. Maybe I should change my habit but I wish there was a "create type def" option on the bd right click menu so I didnt have to change to control, switch to fp, customize, then change back to constant.
