I was going full speed programming block diagrams, and, of course, not stopping to put any documentation in the block diagram, and I just got this idea:
Wouldn't it be cool if you could drop an emoticon, similar to what is done in a written manual (a circled question mark, triangular warning, etc.) into a panel or block diagram, which when operated, opens an info pop-up, or links to a paragraph in the VI info or to a help file?
