| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
The database toolkit is limted by the database variant to data function. It can only cast to a labview datatype as long as you wire that datatype to the type input. This means that you have to know the datatype of any SQL query in advance (or convert to string). It would be very useful if the function would also accept a variant datatype. This way it would be possible to cast any complex type into labview datatype, without the need of a predefined cluster.
Image - casting the database input with a the variant type input (circled) doesn't work
