QFang
error ring "format into string"
Status: Declined
It would be very handy if there was a way to get the descriptive text 'out' of an error ring constant.  It might not be possible on an error control/indicator since it (presumably) involves a (database) lookup of some sort, which may not be available at run-time on certain targets, but for an error ring constant, it should be possible to pass it into a "format into string" just like you can do with enums to get the string.
This is similar to, but not the same as this idea on the format into string taking the error cluster
(Note that currently, there is no way (that I can think of) to get the "descriptive" text that you can read some of above ("Not allowed whil...") from the error cluster/constant, which is rather anoying.)
QFang
CLD LabVIEW 7.1 to 2016
12 Comments
QFang
Active Participant
That would also be helpful, and THANK YOU for reading, responding and in general being so active and approachable! You rock! -Enjoy NI Week (hopefully!)
QFang
Darren
Proven Zealot
Status changed to: Declined
