wiebe@CARYA
extend default reference of property\invoke nodes
Status: Declined
An unwired property node of class VI defaults to the current VI.
An unwired property node of class Applicatio defaults to the current Application.
Why does an unwired property node of class Panel defaults to the current VI's panel?
This only makes sense to have for these classes (and some scripting classes not mentioned here):
Application
VI
Panel
Project
only to these classes it makes sense, because a VI will always have exactly one! Well, not Project, since a VI can exist outside a project, but it still makes sence to me to default to the current project if it's there...
6 Comments
crossrulz
Knight of NI
You obviously haven't played around with splitters.  Your VI can have more than one panel.  The splitters split your front panel into many panels.  Therefore, it doesn't make sense to have a default of "this current VI's panel" since LabVIEW doesn't know which one you mean.
wiebe@CARYA
Knight of NI
You are wrong. Splitter make panes. There is only one panel.
crossrulz
Knight of NI
Oops.  That's what I get for not double checking myself.
AristosQueue (NI)
NI Employee (retired)
A VI can only have one panel *today*. 🙂
wiebe@CARYA
Knight of NI
If we are going to get a MDI interface, I dont mind if this doesn't make it.
Darren
Proven Zealot
Status changed to: Declined
