Imediately after posting this I found the "find all instances" for a typedef sort of right there in front of me. ![]()
But finding all instances returns the typedef used as a control. It would be useful to be able to find all instances of a typedef constant from the right click menu.
The right-click > Find > All Instances menu option on typedef controls will also return constants in the find results.
