How often do you find the need to orginize data into a table format while documenting your vi? I for one, could & would use it all the time! Creating a resizable table free label we all use in word & excel seems like a simple task and would aid in organizing and documenting data into a more readable format. A ctrl+double-click or shift+double-click could serve as an easy access method, tab through the contents, and resize rows and colulmns vis a cursor change while hovering at the specific borders. Free Label, New type, table format, organize data, rows, columns.
