Community Browser
Post an idea
When developing an unattended installation, creation of the specfile allows customized installation choices.
Due to the number of choices, I have rerun 2013DS1DVD1_ENG\setup.exe /generatespecfile more than once and NI Device Drivers DVD - February 2013\setup.exe several times to add or remove one or two options.
Adding the capability of loading a specfile when launching setup with /generatespecfile filename1 /loadspecfile filename2 would allow the easy editing/modification of the specfile by the installation creator reducing the time necessary to make a custom automated installation of the NI software.
I know that we finally have the Version Conversion board to handle all the "convert this to that" requests that people used to post.  Related ideas that have been suggested include 1) a webservice to convert VIs automatically and 2) a specific LabVIEW utility to do the conversion for you.
What I suggest is something a little different and maybe simpler for NI to create.  I would like the ability to open a higher version, non-functional VI  with the following options:
  • The ability to see the GUI and block diagram of the VI (maybe as just image files if NI can't handle it otherwise).
  • A dialog box (or something like that) that gives a summary reason why the VI won't run in your version of LV.
  • Question mark icons where offending subVIs reside in the block diagram.
I think this would be useful because it would at least let you see how the VI functioned - sometimes that's enough to help you figure out a problem.
Currently if you use the new error constant ring and want to save your VI into a version older than 2012, you get a broken code telling you that this object doesn't exist.
It should be automatically converted to some code as it's already the case for other new functionnalities.
I am communicating to parker motor controllers through the Ethernet (parker sample code). Apparently since it is Ethernet based, the code uses socket, where the sockets require admin rights (another discussion about ethernet based and admin rights). In order for my VI to connect to the controller I need to run LabView as an administrator. The problem is I am making this program into an executable for production work.
When I create the executable it will not connect to the controller unless I am running the application as an administrator. As this program will be used in production I want it to be as simple as possible to perform. I don't think there is a simple way to change the environment to run without the need to run application as an admin. Are there any ideas to either change the executable to run as an administrator through the application builder? My plan is to create an installer through the application builder.
Some ideas that I had is to create an installer file and create the executable. Change the privilege level of the executable (properties>compatibility>privilege level>run this program as an administrator). Use a batch file to install drivers and application, then replace application with the one with the elevated privilege level. Another idea I had is use a batch file to do a runas command to run application as an admin. I cannot get either method to work. Does anyone have ideas?
Dear All,
Currently to use LabVIEW in a functional way you have to spend about $5000 to get the bells and whistles.
Large corporations don't have a problem, but there is a lot of normal people that would like to have LabVIEW but are not students and can't justify spending that amount on software that they may use only occasionally, but would like to have.
Adobe has moved away from the (legacy) model where you buy and own your copy of the software, to a subscription based model ($20 to $50 a month) where you get ALL the LATEST version of EVERY application they make, as long as you pay your monthly bill. I was reluctant to use that model but I finally subcribed, and let me tell you it saves me a ton of cash, and I get whatever I need at the latest version.
National Instruments high-level management and marketing department should seriously consider moving forward and making an AFFORDABLE monthly subscription scheme, like Adobe succesfully did. This would benefit NI by getting some money out of folks like me, and would ensure that the whole world would be using the latest versions of it's products.
Successful companies are the ones that make available the best products and services to the BROADEST range of people (e.g. Google, Microsoft, Adobe). Restricting access to technology based on income will hurt National Instruments in the long run.
With best regards,
Rollin McCarty
When you create an installer package with a default destination path that is not available on the machine where you want to install the package later, the installer stops with an error message. You have not the chance to install the package somewhere else.
So my idea is to show a warning only and let the user define a new location afterwards.
here I create a installer with the default destination path D:\...
When I run this installer on a machine that has no D:\ drive, I have no possibility to install the package. I also cannot select annother location.
Note: of course a bigfix for this problem is a default destination path that is available on every machine (e.g. c:\), but in some usecases you want to force the user to install the application in a defined folder like D:\tools\
The I2C Digital Waveform Reference Library is a good choice to test the I2C Interface with timings that
are outside the specification. This is important for the developers to invesigate what happens when a
new designed chip get a not specified I2C signal.
Citation from the readme file:
Supported Targets
This component is compatible with the following LabVIEW 8.6 (or later) targets
  • LabVIEW for Windows Vista/XP/2000
The API library and installed examples may be compatible with other LabVIEW targets, but they have not been tested.
Unfortunately the Library needs the LabView 8.6 Run-Time Library installed and it is not certain that it work with Windows 7 and
LabVIEW 2012. (I tested it and it works with this combination Smiley Happy ) It would be nice if the Library can be updated and tested for
Windows 7 and LabVIEW 2012, to prevent that developers are uncertain if this "old" Library still works.
I often have to duplicate a system, and it is hard to find and install the exact same driver versions.
If I download the drivers separately I often end up with many large files since much content is added to all drivers.
I would be nice if I could configure a list of required drivers (with specific versions) through a web page, and then download a single installer file containing just the selected drivers.
A customer has expressed interest in having the LabVIEW Developer Suite Installer provide an estimation on how much disk space will be required for selected components. Specifically, the application in question is where the customer sets up LabVIEW on several virtual machines through VMWare, and needs to know how big of a hard disk is required on in the virtual machine configuration options prior to going through the installation processure.
Hello!
For anyone who works on a PC that is not connected to the internet, but is is using a third party instrument, they could experience problems trying to view example VIs that ship with the instrument driver.
Currently with LV 2010, if one does not have an internet connection on a PC and navigates to Tools » Instrumentation » Find Instrument Drivers..., the NI Instrument Driver Finder Dialog Box will close after displaying the following pop up:
Please made the NI Instrument Driver Finder available for PCs not connected to the internet.
Since the customer already installed the driver for his third party device, the Agilent E8364C, I made him aware that all of the top level, demo VIs are located on his machine in the *.llb file of his driver under the instr.lib folder.  This work around will suffice for this customer, but anyone without knowledge of our directory structure would struggle with this.
Thanks!
Shawn S.
I am currently working on a quite large project, addressing different customers / users. Therefore I have in this project several specifications for executables and for isntallers. The point is, I would like to be able to right-click an installer build specification, choose build, and every executable used in the installer specification is built as well. Today, I have to remind and select all required executable specifications, and build them prior to installer building.
When you want change the color of some text on font panel
the is not linked or not operating to tool palette color function
instead selecting the string and going to menu bar and changing the font color
So it would be better to change the color of label in front panel by tool palette options,
I feel, if this option is there it would be good
How come you can't tell which version a .vi was created in until you open it? How come you can't just tell whether it was created for 7.1 or 2010? An idea is to have it save a different .vi extention, much like in Microsoft Office, for exampe, a 2003 version would not open a 2007 version, and you can tell before opening because of the .xls or other extension.  For labview, it could be like for 7.1 it was .vi71 and for Labview 8.2, .vi82, and for 2010, how about .vi2010?
Maybe this could come in handy for those who are looking for certain vi's of a certain version.
I have used Labview for about 10 years, the last 4 years complete full time as my actual job requires it, several times I have gotten a tired sight which made difficult to read Labview code, I really wonder if there are plans to add some zoom functionality.
In fact it would be nice to have a magnifying glass on the tools pallet, with a sort of resizeble frame that let you follow the code. There should be an rights explanation, because I feel this idea is kind of obvious, and also I am sure that tons of new users quit trying because this lack of functionanlity.
anyway let me know your comments,
This is not my idea, but I did not see it here and it is a good one so here goes. A lot of people used to deliver chunks of code as DLLs or EXEs but not use them as DLLs or EXEs. Instead they would use them like LLBs and make VI server calls to them. This was possible because when it came right down to it, these DLLs and EXEs were LLBs with extra stuff. This changed after 8.2. No worries because there is the source distribution. Except that the the source distribution is exactly what it sounds like. It is a copy of the source meant to be sent to some other developer. It does not do any of the compile time processing, such as remove conditionally disabled code, that the DLL and EXE builds do. Delivering drivers and other chunks of code as LLBs is a convenient way to distribute patches and so on. But if any of your code has conditional disables, it won't work. The suggestion is to allow the option in the Build menu to remove conditionally disabled code from the source distribution. Here is a thread that discusses the issue. http://forums.ni.com/t5/LabVIEW/conditional-disable-no-longer-works/m-p/1109759
The default installation of LabVIEW, along with any associated binaries, should include an encrypted file stored in a strictly restricted location. This file must contain a list of cryptographic hashes for all installed files. The system should verify these hashes regularly, and alert the current session user if any binaries are newly introduced, replaced, modified, or deleted. This represents the minimum expected standard for securing the environment.
I installed LabVIEW 2020 on my PC and my friend is working with LabVIEW 2016 every time I open his projekt now it gets upconverted and if I downconvert it to 2016 I can only do it via the special option, which does not even allow me to overwrite the original 2016 files. Iam stuck with 2020 since I did not buy SSP GREAT, how is this in any way userfriendly? Its worse then the compatibility of Word with Libre office.
That was Bryans original post 12 years ago, its still the same.
https://forums.ni.com/t5/LabVIEW/How-do-I-continue-to-save-for-previous-version/m-p/4143151#M1194547
When installing recent updates for LabVIEW 2018 an error message came up that said the installer needs access to "My Documents". However this location "file path" is not available.  My company has a drive mapping package that has the my documents located on the server as well as my favorites so it is automatically backed up for recovery purposes.  The installer keeps getting this error and forums state that the IT admins need to get involved every time to update & set my documents to local temporarily to install, then back to the server for automatic backups.  This is very tedious and takes a lot of manpower.  My colleague has the same issue with DIAdem 2018 as well.  Looking to possibly have a fix where it gives the user a browse option to find the file path it needs for the install.
We like to keep the OS installation clean/stock.  That is, install RHEL and any packages required for the engineering applications and try to keep the installation packages to the minimum that are required.  Typically the EDA vendors will have a script that checks that all of the Linux package required the application.  If we find any dependencies we install on all machines.  The LabView Linux installation script wants to be run as root and install packages.  Would rather see a dependency check script so that we can install the dependencies ourselves and know what is being installed.
For the application tool itself we don't want to install in /usr/local on all machines but rather install into a NFS mounted file server so that we only need to install once and not install on each machine individually.  The current Linux installation script doesn't take an argument to specify an installation directory other than /usr/local.
