Community Browser
Top Authors
Post an idea
When creating an Installer for a Labview project, make it possible to execute not only exe files after installation. It shoult be also possible to execute *.reg or *.bat or other files.
This should work for the two options on the Advanced page of the Installer property dialog:
      We know there are lot of posts in Version Conversion Board  for conversion of VIs and DLLs from one version to the other.In other programing languages like .net we can see the 'VERSION CONVERSION WIZARD'.Using that we can easily convert from one version to the other.Why there is no such conversion wizards in labview?It will be very helpful.Is there any problems for creating a conversion Wizard?
I strongly forwarding the idea of a version conversion wizard.
Currently you cannot perform a binary compare on two 'identical' exe's or installer builds. We need a way for our configuration management folks to build an exe per instructions and verify it is the same as what I built. But there are differences in the binary files due to time stamps and other things. Does anyone else need this functionality?
Today LabVIEW 2010 has the option "Save for previous version" because it upgrades automatically the VI to the current LV version (this happens since I use LabVIEW).
This behavior may cause headache when you are working with different projects that uses different versions of LabVIEW. If your last used version was LV 2010 and you double click a LV 2009 VI, it will be saved as LV 2010 VI and your LV 2009 project will crash.
My suggestion is, change the default behavior by keeping the current VI LabVIEW version and provide an option to upgrade to the new version.
Doing this everybody will be able to work with LV 2009 projects in LV 2012 without have LabVIEW 2009, 2010, 2011 and 2012 installed in the same computer.
Cheers,
As of now, a Tab Control Page can be colored via Tab Control and Page property nodes. It would be nice if Tab Control Page Label can be colored, sized, and styled using Property Node. This feature should be incorporated in the future release of LabVIEW.
The Windows 7 file permissions in the Program Files directory are causing a lot of headaches, especially with *.ini files of existing applications. It would be nice if LabVIEW had an option where install file paths of these files could be set based on the system they are going on. For instance, if the installer is being run on Windows XP, the installer will know to put the ini files in <Program Files>\<App Name>\Config but on Windows 7 install the files to <User>\Local Settings\... or whatever we choose.
Right now it seems our only option is to build 2 installers and have a batch file decide which to run. Unless, of course, someone can tell me otherwise.
I have recently installed a new PC under Windows seven with the complete 2010 developer suite ...
On this PC i have to run an old CVI application which use traditional Daq ... and it don't work for known compatibility reasons !
But i get this information after many web searches and NI support investigations ...
It should be nice to add a compatibility icon in the developer suite and device driver installers, in order to view the compatibility of each product to install.
It should be a way to rapidly know if a product will work or not, or will perhaps work with no garanties ... on a specified Operating system.
The icon should be something similar with a traffic light : Green => The product is OK, Orange => The compatibility is hazardous, Red => No compatible at all !
Manu.net
The list of available destinations when you build an installer includes Common App Data Folder, but not Personal App Data. So instead of being able to just install an initial set of settings during installation we always need to hard-code the creation of those files.
It would be conventient if PersonalAppData was available as a destination as well - or even better; that the options included *all* the OS's standard folder references. Or that you could at least create new references to such system folders.
I work as a LabVIEW integrator and for one of my customer I develop application, with maintenance goal for their installation all over the world with RS232 or Bluetooth communication for example, deployed on targets as PDA (PocketPC 2003 & Windows Mobile 6) or Touch Panel (Windows CE 4.2 to 5.0) using LabVIEW 8.6 Mobile Module.
This LabVIEW additonal module works quite well to deploy the same application in this differant targets, but I encountered some problems and I have some suggestions for Mobile Module :
1/ MMI (Man Machine Interface)
      -  for graphics indicators (as Gauge or Slide) graphical object ramp or multi Slider is deleted by LabVIEW when you build an EXE => I think that a graphical objets with all its graphical property could be added in Mobile Module (and works on these all targets). See examples in GraphicalObjects.PNG
      - as I say in my introduction my application is deployed all over the world and usually I used "Caption" dynamic modification for multilingual management for all my controls & indicators. But in mobile module we can't do this (but we can modify dynamically boolean text), so I think that it could be possible.
2/ VISA (& Bluetooth) Management
      -  I think there is a bug with VISA installation. Indeed with the installer you can choose the installation directory (default directory or specific directory : in non volatil memory) but if you don't install VISA support in default directory it doesn't work (with PocketPC 2003 for example) I think that could be resolved
-  As I said in introduction my application could communicate throught different protocols (RS232, Bluetooth) and with LV 8.6 Mobile Module we can now use VISA : great !!!. But in Windows Mobile 6, VISA does not support bluetooth (it seems to have an incompatibility with virtual aliases in the registry) ; and in PocketPC2003 it works very well. I think that could be resolved
Currently, if a new version of LabVIEW comes out with new shortcut menu plugin or a quick drop shortcut, that is written in LabVIEW the only way to have that added for older, still supported versions is to save them to for the oldest version, and copy them to the respective folders.
I wish, that the new features in these categories would be available trough download for the supported LabVIEW versions for everyone that has a license.
I would love, if these were separated into their own package, that is a dependency of the LabVIEW installer, but could be updated later from the package manager.
Flatpak is a distribution-agnostic package manager, as long as Flatpak is installed on the system, the same Flatpak package can be installed on any distro. A Flatpak package contains not only the application, but the libraries needed to run it.
So, if NI creates flatpak package with LV and all of its dependencies, then we would have a LV that it's able to run in any distro! Without to having the hassle to manually support every major distro or (like at the moment) only supporting a few of them.
Ello,
Many of us have to install multiple versions of LabVIEW on a development system due to legacy projects where the benefits of transfer to newer versions of LabVIEW are outweighed by time and risk.
What I'd like to be able to do is have modern versions of drivers etc installed at the same time as legacy ones that are unsupported.
For instance, I have IMAQdx installed for LV2019 and LV2016 using VAS 19.5, which is only backwards compatible down to LV2016 (ref). I'm trying to install IMAQdx 4.2 to be able to use it as part of an LV2013 installation, but the installer will always tell me that there's no need, I've got a newer version! Unfortunately, said newer version isn't compatible with LV2013.
My workaround is to uninstall IMAQdx and IMAQ 19.5, install 4.2, then deal with the consequences afterwards. The other alternative would be to set up a series of VMs for different versions, but that's easier said than done in my company!
Consolidate all LabVIEW G files into two file extensions:
  • Source LabVIEW File (*.xx) - Human readable source code files (e.g. *.vi)
  • Compiled LabVIEW File (*.xxc) - Compressed compiled binary files (e.g. *.vic)
Justification:
LabVIEW is proprietary. I need LabVIEW to open LabVIEW files. There are +15 LabVIEW file extensions to create LabVIEW G code. Recognizable LabVIEW extensions are worthless because I still need LabVIEW to open and edit the files. Some LabVIEW files contain compiled code, whereas other LabVIEW files are glorified name-spacers; some are UI components, while others embed compiled LabVIEW code into other LabVIEW files.
With every new LabVIEW version, capabilities are added that inherently cause inconsistencies between LabVIEW file types, environments and overall behavior. Let me explain.
Problem:
  1. Current LabVIEW file types don't adhere to consistent behavior:
    • Libraries (lvlib, lvclass, xnode, xctl) are xml files (human readable) but also contain encoded compressed data (non-human readable)
    • VIs (vi, vit, vim, ctl, ctt) are binary files that can contain compiled code (or not)
    • Libraries (lvclass) add dynamic capabilities like dynamically dispatched VIs and can embed class private data controls (or not for interfaces) using the same extension, rendering the extension useless
  2. Inconsistent code redistribution
    • Distribution libraries (llb, lvlibp) embed compiled code differently
    • Packed libraries (lvlibp) resolve system paths differently that source
    • Libraries (lvlib, lvclass) lack the capabilities to embed reusable libraries for redistribution - Similar to Python's PIP library
    • Some 3rd party applications (like VIPM) to manage distribution inconsistencies add more file types and compounds the redistribution problem
  3. Compatibility discrepancies
    • VI (Poly, Express), Class (Class, Interface) already introduces development idiosyncrasies that could be resolved with a one "file" fits all methodology.
    • More file extensions equals more variability, increased maintenance time, and puts ownership on developer community to find discrepancies
Proposed Solution:
  1. Consolidate current LabVIEW G source files (vi, vit, vim, ctl, ctt, lvclass, lvlib, xnode, xctl) into a single Source LabVIEW File (*.xx) that is human readable (i.e. xml) that contains no encoded, compiled or compressed data. - Similar to NXG's xml format
  2. Introduce Source LabVIEW File (*.xx) nesting/namespacing to remove the need for external Library files (lvclass, lvlib, xnode, xctl) - Similar to how C# or Python files allow for multiple methods within a single file.
  3. Add a build spec component to generate a Compiled LabVIEW File (*.xxc) that embeds the Source LabVIEW Files and Compiled Object Cache - Similar to Python wheels/pip package manager
  4. Allow developers to use the Source LabVIEW File (*.xx) or Compiled LabVIEW File (*.xxc) interchangeably in their development projects - Similar to how Python's *.py or *.pyc can be called
Features:
A single LabVIEW Source File (*.xx)...
  • can be human readable (i.e. xml) - Editor agnostic
  • can embed one or more LabVIEW Source Files - Single file libraries
  • replaces *.vi, *.vit, *.vim, *.ctl, *.ctt, *.lvlib, *.lvclass, *.xnode, *.xctl
  • adheres to common coding language extensions (C#=cs, Python=py, Java=java)
A single LabVIEW Compiled Files (*.xxc)...
  • is a specific build specification for packaging and distribution
  • contains the source files (optional) and compiled object cache
  • can embed run-time components - Package distribution
  • adheres to common coding practices (Python=.pyc, Java=.jar)
  • replaces *.lvlibp, *.llb, [*.exe]
LabVIEW currently has +15 extensions to develop G code:
(Not including, LV Projects, NXG, VeriStand, TestStand, LabWindows/CVI, etc.):
- Virtual Instrument (*.vi)
- Virtual Instrument Template (*.vit)
- Malleable Virtual Instrument (*.vim)
- Control (*.ctl)
- Control Template (*.ctt)
- Virtual Instrument Library (*.llb)
- Library (*.lvlib)
- Class (*.lvclass)
- XNode (*.xnode)
- XControl (*.xctl)
- Packed Library (*.lvlibp)
- Palette Menu (*.mnu)
- Run-Time Menu (*.rtm)
- Data (*.tdm, *.tdms, *.lvm, *.bin3, *.rc)
Should we consolidate?
I think it is useful if the installer automatically 'Force Re-install' if the same software has been already installed with the computer. This will omit the procedure to kick-start force re-installation via command prompt, some users may not be familiar with.
How about an NXG home edition, so folks can try it without any heavy time or cash commitment. It would help acceptance and uptake in the LabView community.
Hi
I'm about to upgrade from LV8.2.1 to LV2013 and then there is a lot of unsupported properties and methods in the new version.
It would be very nice to have the possibility to find those unsupported stuff.
Actually NI seems to need that function too. smileywink:
Take a look at this thread I made a while ago.
"http://forums.ni.com/t5/LabVIEW/how-to-find-unsupported-methods-2Fproperties/m-p/3032045#M865373"
regards Bjarne
Right now in labVIEW the plots can be exported into excel and can be saved into different  image formats (*.png,*.jpeg,*.eps,etc,.). In addition to the other properties it would really a very cool and excellent option to save the plot data as a LabVIEW figure with an extension "vifig" (*.vifig). The idea here is when the  plot is saved as LabVIEW figure the tester with the help of an interactive tool or some thing like this reload the *.vifig to view, change the graphic object properties , maipulate legend, xaxis label, yaxis label so on... and finally save.
Let's assume a situation where the user wants to analyse the data (zoom in, zoom out, find delay etc.,) and change few properties the the data who doesn't know LabVIEW and he needs to use another programs like origin, excel etc. This could be done very easily witht he help of an interactive tool. Unlike LabVIEW, the softwares like MATLAB, Origin has such a pretty useful option.
Thank you.
Problem:
As much bug as suggestion, but since it's been this way for a bunch of years i assume it's a "feature"
I just had a project in which i defined some DAQmx tasks in the project, but in order to get them installed on the target i need to:
1. Export the tasks from the project
2. Select import MAX tasks in the installer which starts and forces me to run a new export.
3. Re-export the tasks from the project to overwrite the max export ...
(yes i could have skipped step 1 had i known the cumbersome mess)
Why cant i simply select a configuration file to include in the installer?
Why cant i select/choose tasks defined in the project?
If i want to avoid the exporter i need to edit the project xml, that's not acceptable.
Solution:
Allow to simply select a configuration file to include in the installer
Allow select/choose tasks defined in the project
/Y
Hello LabVIEW Experts,
I thought of this recently when I was setting up a test computer.  I started up my LabVIEW project file and opened up my host VI only to find that I had some broken wires... DOH!  After looking over MAX and googling a few error codes, I found that the test machine I had didn't have RT installed.  That's when it hit me, wouldn't it be great if the VI would have recognized that I was trying to connect to a cRIO chassis and gave me a little pop up telling me what software I was missing and where to get it?  Sure would have made my day easier.
I just bought a new laptop, spent time installing all my non-NI software.  I set up backup and created a system restore point just prior to the NI installation.
I then installed the 2011 DS2 developer kit, with almost all the products.  Something went wrong with the installation.  Nothing is useable, and when I try to uninstall/repair the software windows reports that it is no longer installed and asks me if I want to remove the link.
I tried installing again from the DVD.  This starts and then just quits, no error message.
I tried the MSI Cleaner; this has been replaced with MS Fixit, which might work, but I would have to run it INDIVIDUALLY on each NI product.
Fine.  Time to go to my restore point.  BUT WAIT!  What's this?!!!
All of my restore points are from the Drivers installation.  Roughly 50 points, 8GB, all from the same 15 minute period when I installed the drivers.  It blew away my last good restore.
This is not right.  There should be ONE restore point created when you start the install, and maybe another after it's done.  Clearly labeled.  The current behavior is USELESS.
If this cannot be avoided, you should prompt the user to turn off SR for the duration of the installation (unless that also deletes the restore points).
I called for support and was told to reinstall the OS.  I had meant to do a drive image before the NI install, but thought the Restore Point would be good enough.
Thankfully this is a brand new installation, so I don't have to deal with getting anything off of it first.
