Community Browser
Top Authors
Post an idea
When using the LabVIEW Internet Toolkit FTP library to transfer large files, there is no way to determine the progress.
I propose a notifier be added to the FTP Registry object data. This notifier would be updated by the low level TCP Read Stream and TCP Write Stream vis and monitored by a UI to display progress of the transfer.
See this NI Forum post...
FTP transfer progress bar
http://forums.ni.com/ni/board/message?board.id=170&message.id=470946
Most of the OPC traffic is "non-interesting" regular traffic. But if there is an error it is a very interesting information. There should be an option to log only OPC traffic erros to log file. Nowadays these errors are marked in red color in log file. Of course it should be a possible to log all traffic as it is nowadays.
It could be useful to simulate problems between the devices and the OPC Server (NIOPC Servers for instance).
Adding new optional parameters to DataSocket Write, as such as, Quality, Substatus and Limit Status (Extract from: http://www.visavisoftware.com/Html/OpcServerQualityFlags.htm), we could create different situations to test our applications.
This is a possibility:
TCP/IP, UDP/IP, IrDA
LabVIEW doesn’t have any VI or function to retrieve connection information/properties like IP address, local port or service name, remote port, ect.
In order to get connection information, you have to make a functional global vi to manage connection information by connection ID for later to retrieve.
Native function or VI will be great help.
Currently the synchronous and asynchronous modes of writing data have little to no effect when communication over TCP. The write will return immediately after buffering the data to be written. However, the data it self may take considerable time to actually be written to the network. Absent some type of hand shaking at the application level there is no way for an application to wait until all the data has actually been written. The native LabVIEW TCP Write behaves in the same manner as the VISA write. Given this behavior it is impossible to implement a well behaved write queue for queuing up and transmitting data to a device. For example a normal print queue will open a connection and send the data to the printer. It will not attempt to open a second connection for the next print job until the first one has consumed all of the data. If a large amount of data is being written it can take time for all of it to be transmitted. The way the VISA or TCP write VIs behave the print queue would open a connection and write the data. However the call to the write would return immediately because the lower level network stack has accepted the data and buffered it. The print queue then believes the first job is complete and begins processing the second job. This will mean that a second connection will be opened. Some devices will allow multiple connections and some do not. However without the ability to actually wait for the data to be completely written the queue would have to continually try to open connections. This would be unnecessary network traffic and and unnecessary communication with the printer.
I would like to see an open on the write VIs to allow for a true blocking write. The write will not return until the data has truly been transmitted. The current behavior is also valid and can be retained.
Note: I have not tested the behavior on other types of interfaces so I am not sure if this is a TCP only issue.
The current VISA read and write primatives do not have the ability to abort early. Under many circumstances if the timeout values are short this is not an issue but it can be an issue if a long timeout is required. The current work around is to use a short timeout value and loop continually ignoring the individual timeouts until a threshold has passed and then pass the timeout error out. This apporach requires the extra code to "monitor" the process of the communication. It also requires shift registers and associated logic to maintain the data. It would be desireable to simply set the timeout for the desired value and have a separate VISA property that can be set cause the current operation to abort.
Currently the native (by which I mean noncustom) numeric data types for shared variables are pure numbers (i.e., without units).  It is simple enough to add units to, say, a DBL numeric control and define this as a custom type, but the DSC module does not support value-based alarming for custom types.
Since
1) we would like to support value-based alarming AND units
and
2) I suggest this is (or should be) a very common use case
I propose that LabVIEW have numeric types with units as native shared variable data types.
I suggest that using units for engineering applications would be both more convenient and safer
I also think this would be quite simple to implementThe only question is on which unit to do the value-based alarming.  (Likely this would be on the SI unit on the wire.)
I have attached a very simple example that shows the current state of things.
Currently VISA only has a single timeout value and there are use cases where a different read and write timeout is required. Today you need to constantly modify the timeout between each read and write. It would be prefered if these timeouts could be set independently.
LabVIEW currently porvides TCP and UDP primatives. It would be nice if it had a PING primative as well.
Most email server need authentication not only for POP3 to retrieve emails but also for SMTP.
This issue is coming up for a lot of years from time to time. In deed the SMTP Email library built into LV is unusable today.
Everyone is complaining about spam which often is send using open email servers without authentication so you have not the chance to find the real sender of unwanted emails. Since most of use are not this kind of senders we have regular account needing to authenticate.
