6 | |
2 | |
2 | |
2 | |
1 |
When a cluster contains refs to different type of controls that have a common ancester, the "cluster top array" primitive should be able to handle it instead of having a broken wire.
Indeed, if the lower snippet works, one can assume that it shouldn't be too hard to get the upper one to work as well when possible.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
