I'd like to have the LinkedInputTunnel option also for a selector terminal.
Duplicate of Linked Tunnels should work on Case Structure's selector terminal
Which is a duplicate of Allow Case Terminal to be selectecd as Linked Input Tunnel Create and wire Unwired Cases
