Usually I have code inside a loop (e.g. a while loop) that later I need to put outside (or viceversa). I need to drag the code outside the loop and re-wire the cables.
It would be great if some shortcut, for example ALT-drag, allows me to drag the code maintaining the cables wired.
And If there were not cables before, creating automatically the tunnels.
