Hi all,
image processing is not anymore the "tough stuff"/"niche" of the past. Videos are everywhere now, maybe even more than sounds. So functions that handle video should be included in the cross-platform standard labview, at least for the essential functions (reading/writing files with a minimal set of codecs, acquisition of frames through ip or usb for common protocols, conversion between image format for display and processable data). This would attract a lot of young users. It would also jumpstart future developments of labview in the direction of AI.
Thx
