ouadji
input of conditional terminal should be "pass through."
Status: New
the input value of the conditional terminal should  " pass through "
                  (like the "case selector" of the "Case Structure")
                                                         like this,
24 Comments
AristosQueue (NI)
NI Employee (retired)
GregS: I don't know about you, but the optical illusion there makes it look to me like that is still a full-width box. You need to lose two more pixels of width to really make it look like "this is only a left-side terminal".
JÞB
Knight of NI
Thinking a bit outside the box.  I do that now and thenSmiley Wink
The key points being contended are:
  • What is a loop output tunnel?
  • What is a tunnel modifier?
The RCM clearly delineates between changing tunnel mode and adding a modifier terminal with a horizontal seperator.  Well, thats clear for advanced users- the sublty might easilly be lost for 90+% of users.
So how can we get information to users in a easy to find and understand manner? Help is not usually avalable in a RCM contex.  That could be fixed!
Two other things would need to happen:
Or better yet. a nice clear section on loop outputs that makes sence linked to some great example code, hopefully with a working "Open Example" link.  Not all the help to example code links workSmiley Mad
X.
Trusted Enthusiast
Trusted Enthusiast
This conditional connector is some kind of mutant with special power.
Witness this:
The conditional indexing menu is perfectly functional and you can do this:
or that:
and creating an indicator works fine:
But wait! Is it actually capable of concatenating strings?
Let's try to create a control:
False alarm...
wiebe@CARYA
Knight of NI
