6 | |
2 | |
2 | |
2 | |
1 |
I've been unable to find how to access the Waveform Chart property which would be called Legend:Number of Columns or LegNumColumns. I have a customer that prefers the plot legend as a row at the top of the chart as shown in the attached example image. This can be arranged in the editor or with VI scripting. If the number of plots on the chart change during run-time, however, it doesn't seem possible to adjust number of columns in the legend. Setting the Legend:Number of Rows or LegNumRows property makes the legend adjust from being a single row to the usual single column. This makes adjustments to the number of plots displayed on the legend (as a row) difficult, if at all.
