It would be really helpful if you could assign the probes to a ‘group’ and then order the list by that group designation - instead of the probes being automatically grouped and sorted by the VI they relate to.
Or if they’re custom probes it would be good to be able to group them by the TYPEDEF they’re based on.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
