CaseyLamers1
multiple inheritance
Status: Declined
I want to suggest implementing multiple inheritance.
I find that I regularly want to use building blocks in my applications.
An example from my project:  I need a serial device class and an analog device class.  I have a power supply class and a flow controller class.  Now if I have a "serial flow controller" or a "analog flow controller" I could have a Flow Controller base class and use serial or analog children.  Or I could say I have a Serial base class and Power Supply and Flow Controller children.  Either way I end up duplicating one set of code, specifically any configuration type settings via data accessors.
I believe multiple inheritance would fix this.
Casey Lamers
Phoenix, LLC
casey.lamers@phoenixwi.com
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
4 Comments
tst
Knight of NI Knight of NI
Knight of NI
This is what NI has to say about it - https://www.ni.com/en/support/documentation/supplemental/06/labview-object-oriented-programming--the...
What's your opinion after reading that?
___________________
Try to take over the world!
drjdpowell
Trusted Enthusiast
Reminds me of this idea for Traits as a better alternative to things like multiple inheritance.
Darren
Proven Zealot
Status changed to: Declined
_Y_
Active Participant
Active Participant
The original post is old but still Google-searchable. So, this is solution for
multiple inheritance that works with GOOP4 classes: https://azinterface.net/
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
