6 | |
5 | |
2 | |
2 | |
2 |
I make many (almost all) clusters and enums typdefs. This requires a right click go 2 menu levels down to advanced>customize, then select typdef instead of control (which should be the defauld IMHO) then save and the close then select from popup, replace original with control.
I want right click on a control, ->save as typdef, skip the many steps to do what I want. probably could save a minute or two each day here.
