I see that LV 2012 uses the original text font/size/style when pasting text from the clipboard.
LV 2011 and earlier didn't. They just pasted the text using the font/etc of the object it is pasted into.
Is there a way to disable this "feature" or should I report it as a bug?
I didn't turn up anything when I searched for this.
