all know that labview has changed engineer's programmer style of measuremnt and control filed. it not enough , i take a suggesstion to expand labview feature which add machine learning feature. it can aquire data when user developing application using labview, These data include user programming style, the use of professional background knowledge, after training to be able to automatically generate relevant code according to the user. microsoft has started to research this Tech. everybody, if has true, will be changed all progrmmer life.
