13 | |
11 | |
3 | |
3 | |
2 |
Often you see in code one large text box for comments and labels on each section of code for which the comment applies.
How about a small speach bubble type icon which can be placed on the block diagram, which when clicked/hovered on will pop up comments either in its own window or in the context help window. This could be linked into the new requirements tracking tools as well.
Craig
