Ctrl+Shift+A is currrently designated for Align Items. Is Ctrl+Shift+C used yet?
When I try to add the keyboard shortcut myself, it doesn't take. I opened the Control Editor and navigated to Tools » Options, typed desired shortcut, pressed Set, clicked OK:
But again, the shortcut doesn't take. I called NI years ago about this, and the AE duplicated the behavior and filed a CAR. Nothing happened. I currently get this error:
Even if there are no resources available to fix the root issue, could we get a permanent keyboard shortcut for Apply Changes? (Thanks.)
