6 | |
5 | |
3 | |
3 | |
2 |
The "Check if file or folder exists" VI returns "TRUE" if you wire an empty path as input.
According to me, the VI should return false for an empty path.
I think this behavior is very dangerous !
An empty path is interpreted by Labview (Or Windows directly) as the main root C:\.
So the empty path always exists ... but ... is it really what the user wants ?
I think that this default empty value should be replaced by the root directory.
Manu.
