hemalatha
"Close all but this" option for Vis
Status: New
It will be good to have a option like "Close all but this" in File Menu; which will be very useful to close all the sub Vis after debugging and just run the main Vi with all sub vis closed. i feel it would be very good to have this feature.
This is similar to the one in Notepad++.
2 Comments
fabric
Active Participant
A workaround I often use is to minimize the window(s) I want to keep and then just hold CTRL-W for a few seconds... Works pretty well!
K C
Trusted Enthusiast
Another workaround that can be used is CTL-SHT-W. You can select what must be closed (select all and deselect the one you want to keep)
