Many times I face difficulty when I want to assign multiple condition to single case ( Enum type). I need to type text in case structure.
Example: Consider I have 4 state enum ( Case 1, Case 2, Case 3, Case 4). If I need to combine Case 1 with Case 3 then I required to type Case 3 beside Case 1.
I suggest "Combine this case with" option in Case structure drop down menu in case of enum type.
I have attached image for better explanation.
